Re: Weak Plowing
paul
Not on clay like I have it wont.
I had 140hp pulling a 4 bottom plow, took all of that in the tough spots.
Paul
Guy I plowed with was running a 3 18 rollover with a 2 -135 white and I had a 3/14 ih on a 4020 we had all we wanted .
I had that very tractor, it was a 1987. The land I was
farming then was light, almost sandy. I could pull a
4-14 pth Kenvernlands plough no problem up hill
and down. I noticed the tractor in the picture has the
windows open and the roof hatch open as well. The
air conditioning system in those tractors wasnt
good enough. The oil cooler and AC cooler were
jammed in tightly in front of the Rad, and needed to
be blown out almost daily to be able to work at al.
My tractor always ran too hot from June through to
October. And the side panels and grill came off
easy enough but still didnt give good access to
cooling equipment.
Unless you're plowing Irrigated dirt where you don't want a dead furrow or back furrow dump the rollover plow and use a trailer plow and it should pull it all day long. Mounted plows and rollover plows are just dead weight for most regular dryland plowing.
A 5/16 plow here in our clay soil was
enough fpr a 4020 or 966 ...that plow
looks like 4/14 OR 4/12 and much lighter
rollover then deere or international
...cuzthat 885 wouldnt lift a deere 4
rollover off the ground.
