Re: White 6175 tractor problems
rrlund
Have you done a case drain line test on that pump? It sure sounds like what happened to my 2-135.
Oh the convenience of being able to just flick a switch,
rather than pull on a lever, connected to some linkage
that could engage a gear. These electrical parts that
are built for a one or two year model run tractor, are
fine when the tractor is new, but once the tractor gets
a bit of age on it, it becomes obsolete. And your parts
man will tell you in a smug way, we cant get parts for
obsolete equipment.
So all we can do when buying a older tractor is , make
sure you buy a tractor or piece of equipment that had
many thousands of that model built. If there is enough
market for a part, some after market manufacturing
company will produce the parts.
I would try D B Electrical. They got everything. I got a solenoid for a 35 year old atv that Suzuki said was NLA and not even in aftermarket....
My cousin ran into the same problem with a 6125. You can try Heitman Tractor Salvage in Durand WI, 715-673-4829. I don't know if they can help you, but
they do specialize in those front axles.
