Rear-end sludge
rluscomb
I recently aquired a 1950 8N, front mount dist. w/12v conversion. The tractor does run but I need it to run better, anyway, I drained the engine oil (front plug) looked good. Tranny plug (center)gear oil used really thick. rearend plug (rear) came out grayish, sludgy, nasty. would it be safe to say i will have to drop the hydro pump, and what else should be done to clean the crud from the tranny and rearend? I really appreciate your help, Thank-you....
Getting the whole thing warmed up will go a long ways to draining it out... and fresh oil is good.
The BEST THING you can do for your machine is to keep it indoors... SHEDDED! Everything lasts longer and works more reliably when it is put away.
duey
I have a 20 gallon parts cleaner,aand connected a clear hose to it,and pump deisel fuel to remove all of the sludge and grime from the entire area.I removed the top cover to get access.There wasn't much gunk,just a funky mix of water and oil,and a little crud around the pump.I let it drain overnight,then refilled with ford m2c134-D oil. After that,when I changed the fluid,it was clean,no gunk,but if it's as bad as you say,removing the pump is the best idea.---lha
For info on changing the hydraulic fluid, check out tips 3 & 4 at the link below.
There are two ways to clean the pump; the “quick clean” that gets a lot of the crud out of it, & the right way that gets all of it, including the hard packed crud in the pump base.
For the quick clean, after you get the old fluid drained out (overnight is best) remove both inspection plates & start pulling the sludge in the pump base out by hand. Then, get a couple of gallons of kerosene or diesel fuel & pour it into the pump base. Catch it in a bucket & reuse it. (Some folks use a hand garden sprayer.) Flush the pump base out 5 or 6 times. Do not start the engine to run the kerosene through the pump; kerosene and diesel fuel do not have sufficient lubrication properties for a 60 year old hydraulic pump designed to be immersed in 90w gear oil. Some folks say it’s ok to start the engine, engage the pump for a minute or two, then turn the engine off. Your call on that one.
This 'quick-clean' is not nearly as effective as dropping the pump & doing a full job. But if the choice is between doing nothing & the quick clean, spray it out. It worked for me for 3 years on my 1951 N. If you have the time, drop the pump; that is the right way to do it. I’ve done it both ways & don’t plan on doing the quick clean again. If you have hard packed crud in the pump base, you are wasting your time w/ the "quick clean".
With all of the fluid drained out, block the front wheels & get the rear wheels up at least a foot. (you'll see why soon enough) Remove the 4 bolts holding the PTO shaft in & pull it to the rear & out of the tractor. Loosen all of the bolts. Remove all but the 4 corner bolts. Then, carefully remove them. If you are lucky, the pump will drop free (and dump a pint or so of hydraulic fluid down your sleeves). If not, wrestle it free. The pump has 'ears' that fit into the housing; wiggle it a bit & it will drop free. If you have the rear tires a foot or more off of the ground, you will have enough arm room to hold the pump & lower it at the same time. I just drop it in a bucket of diesel (or mineral spirits) & let it soak overnight. Once you get it out & on the bench, just remove the intake & exhaust valves & start blowing it out w/ compressed air. I don't see much need to pull it down any further just to clean it. Replace the pressure relief valve while the pump is out. Reinstalling the pump is harder than pulling it out because you have a gasket to worry about. (no sealer on the gasket) And, you will probably need a helper to guide the control rod into the pump rocker shaft unless you’ve done this 6 or 7 times before!
While you have the PTO shaft out, it would be a good time to replace the seal on it. It's got two spring clamps around it. Take your needle nose pliers & remove the one in the front. Then, hang the shaft & bearing housing in your vice & tap the butt end of the shaft; the bearing cap will come off (and the shaft will land on your foot). Then, remove the other spring clip from the other side of the seal. At this point, remember that you never bought a seal driver & go get a BF socket & drive the seal out. If you have the new style seal, the white side goes out. Put some grease on it.
Contrary to conventional wisdom, not a lot of water gets in the oil from the shifter boot. Of course, if it's bad, replace it, but you get water from the draft control spring & the dipstick. But, most water is just a byproduct of the heating/cooling cycle of the oil.
50 Tips
