FRED VACCARO
I was installing a rebuilt hydraulic cylinder for the three point system at the rear of the tractor and I noticed the one of the bolts that attaches the top link rocker bracket to the rear frame cover was loose. I tried to tighten it but I found that the threads in the cover where stripped out. I remove the other two bolts and found more problems. All three of the bolt holes were broken at some time before I owned the tractor.
My question is: what kind of a fix can I do to repair this problem without removing the cover plate?
I think that the cover plate is cast iron and I assume that the only weld that would work would be brazing?
One idea that I thought of was to drill out each hole area and thread a larger bolt into the cover--then drill that bolt out to make threads so I could use the same size bolts as originally installed?
Another thought was to make a metal plate large enough to cover most of the cover plate and weld the top link use the smaller bolts to hold down the top link,
Any suggestions are appreciated--
