REAR GEAR NOISE
JUST GOT MY NEW WD45 HOME LAST NIGHT AND WANTED TO CK THE POWER ETC OUT. RAN FINE BUT HEARD A LITTLE NOISE THAT SOUNDED LIKE A LOOSE REAR WHEEL A COUPLE OF TIMES BUT EVERYTHING IS TIGHT. WHEN YOU PUSH TRACTOR BACK AND FORTH THERE IS A LITTLE FREE PLAY IN LEFT DROP BOX
Does this happen when changing direction of travel? Check for loose/worn eccentric on the Power-Shift wheel. May also have wear spots on the rails. Easiest fix is to change wheel spacing...find a non-worn setting. Otherwise, tire needs to be removed from rim so rail can be built up.
