I"ve been looking for replacement rear rims for my 1958 TO-35.CC has eaten them up. All the rims have loops for mounting the center. Mine does not have the loops. Is that all there is available, the looped rims? Would really like to replace them with what I have.
No check with a Farm tire dealer they should be able to get you the other style. As Max says a picture will surely help with your question.
Are those you have now 28 inch? or 24? 24 inch rims.. perhaps all are correct for MF's, have 6 loop, or a one 'ring' or 2 or 3 'ring' rims, for the clamping centers. I call these 'industrials', and they are in most commercial tire store catalogs... now, if you do have 28 inchers... you might have 'power adjust rims'...megabucks... yep, show us some pictures...
I repaired mine. Did not desire to shell out the money for new. Labor wise might have been cheaper.
However, repairing them was faster.
Evidently you have the double tab wheels. We picked up a pair of used wheels and tires about 10 years ago for the TO35, one was a loop wheel, the other was a double tab, both 28". The man at the tire store said they were off of a Ford.(?) Not sure if he really knew, but might be a place to start looking. The loop wheels will work with the same centers, just need longer bolts.
Here is a pic of the outside and of the inside.
Yep, lucky you. 2 ring 24's. Any commercial tire store should have them for 150 or less... but try bruce's idea too... see if the old ones can be patched... those don't look too bad from those pics...
