dawsonn
Hello I have a 135 Massey Ferguson with a Perkins d3.152. It has a rope seal in a alum. housing for the rear main seal the manual said that it comes the right lenth, but the aftermarket kit rope seals are about 1/2" longer should you cut off the extra are am I doing something wrong. I have over 25 years in rebuilding boat 2 & 4 cycle engins just no tractors. Thanks
First soak the seals in oil .I use a socket to press the rope seal in all the way, then cut the seal off about a 1/16" inch high.. A small dab of gasket sealer on the ends of the seal and bolt it together..
