Having owned this 49 8N for over 30 yrs and never having to split it, Ive been lucky, and my luck has run out. Being unable to engage the pto or to remove the pto shaft, I pulled the lift cover. The shaft is stuck in the support sleeve (possibly the pump cam also). Im taking the tractor to a heated shop with concrete floor next week planning a rear split. A number of questions..
Once split, should I try to drive the shaft out of the sleeve from the countershaft end with a piece of bar stock, risking damage to the bearing snap rings etc., and not knowing if the shaft might also but lodged in the pump cam, potentially damaging that as well. Or plan to cut the shaft in the pump just behind the cam without the attempted shaft hammering? Maybe try it without too much vigor?
If I cut the shaft behind the cam and remove the pto shaft portion behind that, will I be able to unbolt the pto support and remove the pump, remaining portion of the shaft and support still connected at the sleeve, out through the pump hole in the bottom of the center housing? Or will I need to cut the shaft a second time?
Once removed Ill use a hydraulic press to extract the shaft from the sleeve and cam ( if necessary).
With coupler removed, I plan on using a sawzall with carbide tipped blades (and oil). I cant see a better way since I dont know if the shaft splines are free in the pump cam.
Any input welcomed.
Any input welcomed.
