Rear Tractor Tire Question
JW in NH
Hello,
My question is, if I have a 14.9 X 28 rear tire that needs replacing and someone gave me a used 16.9 X 28 tire, can I use it on the same rim?
JW in NH
Not likely- you can go safely one inch wider or narrower than the rim width. Your 14.9 is likely on a 13 inch rim. If it was on a 14 inch, the 16.9 (old size 15) could fit on a 14. You also don"t want both the 14.9 and the 16.9 on the same tractor. Their profiles are much different.
