rear weights on a 720 Standard
What is the John Deere "A" parts number weights for this tractor? I have been told that the R61727 weights also work. Any help is greatly appreciated!
Leo, Your 720 Standard would take an F1592R rear weight. I think the R# weights were for new gen standards, and have a smaller bolt pattern footprint. Your parts book should be able to confirm the F1592R Pt#. I have that Pt# castings on my 630 and 730 Standards. Ted.
The F1592R weight is the used for two cylinder standards. They are weights used for 26-30 inch rims. The same weight was later produced with an "R" number for the Dubuque utilites and such.
You can use the full size weights A3404R on your standard so long as you install one F1592R weight per side first. The large weight will not fit first, however, the large weights will attatch to the small weights once you have it installed. That means you need at least one set of F1592R weights if you plan to attatch any A3404R weights.
Just and FYI.. The F1592R weights weigh around 120 LBS while the A3404R weights come in at around 140 LBS.
I also recommend using the correct bolts. It makes installation a cinch. The bolts can be found in any of the Waterloo built new gen parts books.
