Rear weights
Will one piece Farmall rear weights weights fit on a IH 966
Farmall H, Yes depending on how much wt you want to carry. Unless you have CaCl & H20 then I would say you need equal # of 2 piece wt for the insides, leaving the 1 piece for the outsides.
For every pair you add to rear corner that is about 300 lbs. You can use the 4 holes in the cast wheel, and the wts and go as wide as 5 & 5 ins and outs fairly easly.
I have a 966 also Mine has the huge one piece aftermarket cast wts 950 + - lbs. No fluid in tires either, cast only. I have a loader on mine so I am a huge believer in cast wt.
So the 2 piece/1piece method as I described above is how I would approach this. 1 single wt is not much help in the grand scheme of things. Hope this helps.
Later,
John A.
I've got two sets of rear weights on my H. The first set is the "split" 2 piece variety that came off of a 1066. The second set is the common one piece variety. All of the mounting bolt holes line up perfectly.
I took 3 sets like you pictured and cut them to make split weights for the inside of my 766. Worked great. My weights came from C's and H's.Kent
