rear wheel clamps
Both clamps are the same.there are a 'bazillion' Hs out there for parts.Someone here on YT may have some to sell.
If you have 2 axle clamps a wheel on a regular H the wheel was changed sometime. If a 8 spoke wheel it's probably off a 300, 350 or 460 2.5 axle or others with 2.5 axle. Some HV 6 spokes used two Axle clamps a wheel. Both clamps were the same and If you want to know about the rim clamps the inside and outside ones are the same.
If you mean the ones that hold the rim to the hub they are very cheaply and widely available, the ones that hold the hub to the axle cost more and are heavier to ship but they're out there too. The rim clamps are the same on both sides of the rim, they are just turned around so they look a little different.
Zach
