rear wheel fluid filling ?
stomperno6
I am look'in for the part advertised for filling the rear wheels on tractor.,it adapts to the valve stem and has a garden hose adapt to it.,any help appreciated and thank's.,larry
Have a couple of those in my tool box, but I mostly use on like this
https://gemplers.com/products/haltec-hydro-inflation-core-ejection-tool
Those with the little bleeder. Need the bleeder taken out, and a stem with a small air line in to vent as it fills. Otherwise the air can't get out to fill the tire. We changed ours to a short piece of air line like for the shifter on a truck transmission. Vents air continuously versus holding the bleeder and getting chloride all over everything in the process. With an old threaded piece and the air line with a flared cap it doesn't leak and vents well.
(quoted from post at 13:06:46 02/22/23) Those with the little bleeder. Need the bleeder taken out, and a stem with a small air line in to vent as it fills. Otherwise the air can't get out to fill the tire. We changed ours to a short piece of air line like for the shifter on a truck transmission. Vents air continuously versus holding the bleeder and getting chloride all over everything in the process. With an old threaded piece and the air line with a flared cap it doesn't leak and vents well.
1/4 poly flow.
I am not at home to take a picture of my setup but this is basically what it is. You still need the Gempler adaptor but the Y adaptor allows for faster venting. Turn off pump, close pump valve, slowly open other valve to a vent bucket. Close vent valve, open pump valve and start pump.
I had the Gempler adaptor and I might have $15 in the Y and various hose adaptors.
