Rear wheel weights 5310 jd
crowspond
Going to salvage yard to get weights for above tractor with loader do they usually put 2 weights on each side they are 110 per weight
All depends on how much you intend to lift. We have about 1200 on the rear with the chloride in the tires. 1 bF&H weight with 1 IH on the outside and 2 old case weights on the inside this is on each wheel plus the chloride in the tires.
That depends upon your use and application. My loader tractor has 3 weights on each side, no fluid, and a 55 gallon barrel with concrete on the three point. That gives some nice counterweight. The barrel is the most effective as it is further away from the front axle, your fulcrum in a tractor with loader application. My other tractors have one or two weights in each rear tire. For my eyes a rear tractor tire without one weight looks naked and/or incomplete.
