Rear wiper kit
David Sr
I purchased a rear wiper kit for my 95 farmall and it came with no instructions. I had read and hoping the cab is prewired but before I start tearing the cab apart checking to if anybody has done this before.
I searched the parts diagrams for this and there is not a separate wiring harness listed for the rear wiper variation. Also, when I checked the cab wiring harnesses, there were only breaks by serial number, not for options. So, it would seem like the wiring is probably already there and you may just have to add the switch.
I can't swear to this, but that is what the parts diagrams showed. Plus it is much easier for manufacturers to install one harness that supports all options rather than stocking and making sure the correct harness gets installed for each option.
It's similar to how every Cummins engine in Dodge trucks had the block heater installed in the engine and if you bought the option they stuck a cord on it, or you could could just buy a $15 cord yourself and have a block heater.
Thank you for the reply. So far this is going very well. It is prewired and I have the motor running still working on the washer.
I?m at a standstill right now. Not 💯 sure where the bracket for the nozzle goes and how the washer hose is to be run.
not sure if this will help, but it's from the parts site
The diagram is different then my lay out but it did help me some to rout the tubing and I thought I found where to mounted the nozzle but I don?t like where it sprays on the glass. Seams it should go on the top center of the roof but there are no pre drill holes there. I?m going to wait and maybe call HI tomorrow.
