RoeFarmall
Greetings!
After replacing the two bearings on the transmission driving shaft, I am having great difficulty mating the end of the drive shaft to the roller bearing in the transmission housing (Transmission Main Shaft Pilot Bearing). The roller bearing was replaced at the same time the other bearings were. The bearing carrier will not mate flush with the dry tube mating surface. I do not want to use excessive force to bring the pieces together. Any ideas?
By the way, I am reassembling a 1947 Farmall "M."
Thank you!
Thank you!
