Rebuilding A Wagner Tractor
Hello everyone, I'm brand new to the site. I'm currently sourcing information on a Wagner tractor. I have a model 9 that I'm going to start rebuilding. Unfortunately there is very limited data on it I can find. I have an owners manual, and a JD WA14 parts manual that is good for cross reference, but what I'm lacking is an actual service manual. I need info on the divider box, more commonly referred to as the drop box.
Hopefully someone out there has a service manual for Wagner's. My divider box is the same as a WA14, & 17. Any help would be greatly appreciated.
Thank you very much!
Do you have a brand name on the drop box. I thought from what little I have heard about the Wagner tractors they were a lot like the Stieger and Versatile where htey had a lot of truck or construction equipment components in them. If so you might find more information from one of them for your individual unit that way. Those older tractors like that were not that difficult to fix like that. I did the drop box in my old IH truck back in the 80's by putting the shafts in with the bearings on one side then put each bearing in one at a time to set shims for the tightness of each with tapered roller bearings on all 3 shafts. Then put gasket and lid on for final assembly. worked for a lot of years like that.
Early 4 wheel drives- google it.
Wagner was one of the earlier brands of FWD tractors in the larger HP. The drop box is hoe the power is transferred from the transmission down to the axle drive shafts. Sometimes if not in a tractor they also contain the front axle engagement for them. In the case of my old IH truck it has 2 levers to the drop box one was a low range for real slow work the second was to engage or disengage the front axle.
Looking at the parts catalog, it's a very simple unit, 4 ball bearings and a BIG Morse chain (6'' wide), NO tapered roller bearings to ''set up'' or adjust.
I looked at the DEERE Techpubs site and was surprised they don't list a Service Manual, only Operator's and Parts manuals.
(quoted from post at 12:00:06 02/04/23)
Yeah me too, I googled a lot to find any source for an old service manual with no luck. I did stumble upon an old post on here where a fella was told to look it up on the JD tech site. The thread ended there so I took a look myself because JD is pretty good at keeping tech data, but they had no service manual. The divider box is identical on the JD WA14,17 as well as my 9.
Thanks for pointing out the roller bearings and Morse chain. That's good to know there is no preload I need to worry about. I have found a few companies that can reproduce sprockets and a HY Vo chain isn't too hard to find either. Bearings are bearings and as long as there is a part number you can get replacements.
Guess my main concern is I don't like blindly wrenching on stuff without info or knowledge, especially when tech support is very small. If you are working on say a JD 4010 and run into a wall you can find info pretty easy. Wagner tech data is scarce and finding guys that know is also scarce. I'm pretty good at figuring out things but always try to find people I can ask questions to if I'm stumped. WagnerTractor.com used to be a good place to find info but that website no longer exists.
(quoted from post at 07:13:32 02/04/23) What IS a Wagner tractor and how does anything JD connect to
it and what is a drop box>
Wagner has been credited in bringing the first articulated 4x4 tractor to North America. The company still exists but is mainly logging now. When JD released the 8010 it had transmission problems as so they needed a temporary replacement unit to stay competitive in the market. They contracted Wagner to build them tractors (WA14. WA17) but that deal didn't last long and due to a clause in the contract Wagner was forced out of business. Rite tractors, and Big Buds were born from the remains of Wagner. Early Big Buds were built on Wagner frames and both Rite & Big Bud rebuilt old Wagners.
The unit was a cast Wagner part, and parts are somewhat still common so that's not the big problem. Where I'm stuck is not having the tech manual to take on the rebuild so I'm doing a lot of guess work along the way which makes me nervous because there isn't a lot of tech support for these tractors if I run into a problem without a service manual.
Correction, bearings may be ''cylindrical roller''.
Part number shown is 201207, NOT sure if that is the Wagner part number or the actual bearing part number, as ''201207'' IS a bearing number.
Ok, I do have an owners manual that lists parts for both the 9 and a 14 (1959). It lists it as a Spherical Roller Bearing #22211. Not a Wagner part but as a vendor number.
(quoted from post at 16:11:26 02/04/23) An interesting project, for sure! What
engine does it have?
It still has the factory JS-160 Supercharged Cummins. My father tried to get it started a few years ago with no luck. Parts are hard to find so I'm going with an 8.3 Cummins which is the same dimensional size. The original R96 trans will also be swapped out for a newer 10 speed.
(quoted from post at 20:20:35 02/03/23) Hello everyone, I'm brand new to the site. I'm currently sourcing information on a Wagner tractor. I have a model 9 that I'm going to start rebuilding. Unfortunately there is very limited data on it I can find. I have an owners manual, and a JD WA14 parts manual that is good for cross reference, but what I'm lacking is an actual service manual. I need info on the divider box, more commonly referred to as the drop box.
Wagner also manufactured forestry machines including chip dozers which at the time were very similar to the ag machine you are asking about. They are now called Allied Systems in Oregon. Not sure of success there but here is a link to their web site.
Dennis
https://www.alliedsystems.com/contact-us/contact-us.aspx
