reduction gear shaft removal
74JD140
what is the best way to remove them? im trying to replace the bearing that it rides on (#JD7672R on a 1950 JD A). the only way i can see getting it out would be out the top where the gear shifter goes into the tranny. anyone know?
You have to remove the shifter cover, all shift forks and rails, and the sliding gear shaft. Might as well check those bearings too. Then you can remove the drive shaft from the inside of the tranny.
Have you removed the reduction gear cover?? That is what you need to do to get to the bearing. The cover will come off and leave the bearing on the shaft. You would have to remove the clutch assembly and pulley first.
i have it about 3/4 apart already. clutch is off, reduction cover is off, reduction gear is off, and the bearing retainer behind the gear is off. i just wanted to make sure i knew what the next step was to removing the shaft. how hard is it to get the shift forks out? ive done this in a truck tranny before, but this is my first time inside a 2 cyl tranny. thanks
Well you got alot more to do. Flywheel needs to come off and the top shaft has to come out and all the shifter rails and forks. May as well go ahead and do the bottom shaft as you are right there and it won't take much more time and they usually have bad bearings on them.
This would be a GREAT time to STOP and go to a local rural king,or tractor dealer and find or order an I&T service manual for that tractor !
Glad to here you have to book. And yes they leave alot of details out. Deere never offered a service manual on the A for some odd reason ? The JD one for the late B is really nice and would help as the proceedure is similar.
