Regular Clutch Pedal mounting pin
What is the diameter of the pin mounted on the tranmission housing that the clutch pedal rotates on?? The pedal mount opening seems to be about 1/8" too big, and did not think there was supposed to be a bushing there. Either the pedal or pin is wrong. Trying to figure out which one.
Id be willing to bet its all the wear over the life of the tractor, youd be amazed somtimes what you discover working on them. One way to fix it is make sure that the bore of the clutch pedal is true as well as making sure the pin is round. Than just put a bushing in the pedal and size it to fit on the pin if you cannot find a bushing with the right inside diameter.
