john18436572
At work we have plant supplied compressed air lines. We have a few large pressure regulators, that feed smaller lines that go to individual equipment and air nozzles for blowing stuff off. Each piece of equipment and air nozzle has it"s own smaller regulator. They want me to label all the regs with what pressure they should be set at. The smaller regs at the ends of the runs need to be set at anywhere from 30psi to 80psi. As a general rule, what should the main regulators that are upstream be set at? I assume that if they are too low there will be pressure losses at the end use regs if they are all being used at the same time?
