reinstalling cleaned HD3 injectors
Forum,
Next week I return to northern Minnesota to complete work on the HD3 Allis fuel injector system. Question is are there any things special I should do when installing the cleaned injectors. Reason for the question is that they were a bear to remove. Any and all advice is appreciated.
only coat the injectors, not the bore , if you also coat the bore you might get antiseize in the chamber as you are pushing the injector in.
