rel valve location
If I remember correctly the main relief for the backhoe is in the inlet end plate of the backhoe valve stack, follow the pressure line from the pump to where it connects to the valve stack and the relief valve should be in that section. Better would be to contact [u:1121c7366a]Floydcountymuseum.org [/u:1121c7366a] Get your Oliver manuals here, at the website of the Floyd County Museum, and get a manual so you can check the pressures using the correct procedures.
