picked up a 641, rewiring back to push button start, 3 wire 12v... has 4 post relay, 2 larger post, starter and battery, 2 small post, S and I, S i have going to the push button start and I going to the block ignition, what am i missing? i get good ground when i push button to the S connector
thanks dave
This post was edited by vidaliaman on 04/08/2023 at 05:21 am.
(quoted from post at 07:36:10 04/08/23) picked up a 641, rewiring back to push button start, 3 wire 12v... has 4 post relay, 2 larger post, starter and battery, 2 small post, S and I, S i have going to the push button start and I going to the block ignition, what am i missing? i get good ground when i push button to the S connector
thanks dave
will guess that "block ignition" means hot when ignition is ON. If so, then most likely cause is incorrect 'relay' (solenoid). There is more than one circuit type that has 4 terminals , labeled the same & look the same, but function differently. The I terminal on a "wrong" type was to apply battery voltage to coil during start and is activated with voltage applied to S terminal, whereas the "right" type for your tractor is activated with ground to one small terminal and battery power to the other small terminal.
As JMOR said, there are a number of solenoids that LOOK the same externally but have different internal wiring.
You want a ''Circuit 4'' solenoid, and the BASIC wiring is as below.
wonder if i have the wrong relay? ordered from YT#105689, i can jump from bat side of relay to starter side and it pops the
starter, i have 12v to I terminal with key on, i have continuity when i press starter button to the s terminal through the
ground,this is going to turn out to be something easy
You need to start with the ESSENTIAL MANUALS; get the Original Operator's Manual, I&T FO-20 Service Manual, and the'53-'59 MPC. You don't need a 12V starter motor or Solenoid (Relay). Relay uses 3 wires. GEN & VR are removed when doing a 12V conversion and in place is an ALT, 1-Wire or 3-Wire, DELCO 10SI typical, with a belt tensioner device to maintain fan belt setting for water pump and to charge the battery. The correct Starter Relay (Solenoid) is p/n FAB-11450-B, $25, and is 3 wires, not 4. dash wiring junction block, p/n 8NNN-14448, $10, Neutral safety Start Pushbutton, p/n 8N11500 $25, all available at Dennis Carpenter Reproductions. Also required is an external 1-OHM resistor if using the 6V coil. Eliminate if you swap out to a 12V coil. The distributor must be rebuilt to OEM Specs: nothing changes regardless if 6V or 12V is used. Here are some documents:
https://i.imgur.com/dlcGHwkl.jpg
<center
In-line external 1-OHM Resistor required if using the 6V Coil.
ESSENTIAL MANUALS:
Tim Daley(MI)
here is discription of the relay i bought from YT... Relay assembly, 12 volt, 4 terminal. Grounded through the base(do i have the wrong relay?
thanks dave
(quoted from post at 08:24:58 04/08/23) here is discription of the relay i bought from YT... Relay assembly, 12 volt, 4 terminal. Grounded through the base(do i have the wrong relay?
thanks dave
Grounded thru base is the wrong relay
You want one with a isolated ground
112395 is the one you need but you can also use 105690
This post was edited by Destroked 450 on 04/08/2023 at 06:54 am.
thanks dave
Double post
This post was edited by Destroked 450 on 04/08/2023 at 06:57 am.
Most ANY local auto parts store would have the SS-567 solenoid (or it's equivalent in the brand they sell) on hand or have it overnite with no freight.
