Relief valve
JD Ga
This is the Relief Valve from my '46 2N. It looks different from the one I've ordered from here. I assume it'll work, just wanted to make sure.
I have only seen 2 different styles of relief valves,,, either will work if the threads are the same,,, I really like the Sparex style valve in yer pix,,, I don't care much for the valve wif the cap altho it will werk,,, its just me or its i believe the one in the pix is rated a little higher on the relief side and i believe it cuzz i have installed both and the one in the pix is to my like'n
Hobo, I got the V6 engine all back together and installed (about killed me!) I have four little screws left over that have torx heads on them and for the life of me I can't figure out where in the ----they came from. Do you happen to havwe any idea where they came from?????Cranked up and runs good but won't idle. The pigtail to the knock sensor was broken and I got a new one to put on it and I didn't have the probe that goes into the intake pipe installed but will when I start it again. Also the pig tail to what ever that thing is in the center of the intake plenum is broken but it is connected. I will get another pigtail for it when I go back into town. Sometimes I wish I just wouldn't tackle these big jobs anymore.
Zane
(quoted from post at 03:34:35 11/08/08) Hobo, I got the V6 engine all back together and installed (about killed me!) I have four little screws left over that have torx heads on them and for the life of me I can't figure out where in the ----they came from. Do you happen to havwe any idea where they came from?????Cranked up and runs good but won't idle. The pigtail to the knock sensor was broken and I got a new one to put on it and I didn't have the probe that goes into the intake pipe installed but will when I start it again. Also the pig tail to what ever that thing is in the center of the intake plenum is broken but it is connected. I will get another pigtail for it when I go back into town. Sometimes I wish I just wouldn't tackle these big jobs anymore.
Zane
May B the cover that goes on the intake,,, dunno but most folks would B proud to only have 4 screws left over :lol:
