relining gas tank
brian(MN)
This is a question for those of you who reline your own tanks. Is the small outlet hole at the bottom of the tank large enough to drain out the excess?. Can't drain it out the top because of a lip inside. How do you plug the holes when you coat the inside of the tank?
Thanks,
Brian(MN)
I save those plastic plug caps off everything and use those or can use corks or tape or old cap or pipe plug. Need those back out after draining so it will dry out.
we have got a leaky fordson diesel tank.
what is the stuff. how dos it work. what is it called.
its new to me.
its new to me.
