Remove rear
I have a JD 320 S , I need to know how to remove the rear nut and Web wheel to replace the seal no.7406 T, because I have oil leaking down the inside of the R. wheel and tire. Thank You
The shaft that the rear wheel web attaches to is a tapered spline. Remove nut with a break-over wrench and cheater pipe or 3/4 or 1" impact wrench.
A giant puller or put wedges between wheel web and final drive housing,loosen nut to where it's flush with end of shaft(to help keep shaft from swelling) and hit with a hammer to jar loose.
The seal 7406T doesn't show up in 320 parts index. The axle seal I located is AM268T which subs to AT48334.
Part Number: AT48334
Replaces Part: AM268T
Part Price: 17.25 USD
Description: SEAL,OIL
Part Number: M214T
Part Price: 4.50 USD
Description: GASKET ,AXLE BEARING QUILL
