Remove SM live hyds.
PretendFarmer
I am removing my Super M's live hydraulics for pulling. I am keeping all the stuff in case the tractor returns to farm duty.
From what I can tell, I only need this:
http://www.yesterdaystractors.com/Farmall-Super-M_Distributor-Drive-Housing_363749R91.html
And this:
http://www.yesterdaystractors.com/Farmall-Super-M_Distributor-Drive-Shaft_353934R11.html
Am I missing something? Thanks.
Not if just wanting to replace hydraulic pump with a ignition drive. Those parts are for a distributor. You should already have a distributor. Remove it from pump and it bolts back to the ignition drive housing after you find one. It's a housing that bolts at each end like the hydraulic pump with a shaft inside and hopefully a good gear on shaft. If not you use drive gear from pump. Where your distributor unit has a stud for a top mount, stud is removed when mounting to ignition drive housing and a bolt used instead.
