Removing 3.152 engine
kermkep
I have started to remove the 3.152 3 cylinder gas engine from my 1974 mf 135. From what I can see everything is disconnected and ready to come a part. I'm having trouble getting the engine to come a part from the transmission. Is there something that I could be missing? It looks like I have all the bolts out around the outside and all the linkage loose. Could it just be tight? I'd appreciate any help. Thanks in advance.
Look close I've missed a lower bolts before.Also there may be a bolt(nut)
on very top housing under where battery sets. Opposite side where other
bolts are.
Hey minor09, You were right. I finally found the bolt that held the starter on went through the starter, then the engine block. and threaded into the bell housing. As soon as I took the starter off
the engine and transmission came apart just as I expected them to do. Thanks for your input. I appreciate being able to get advice from someone that has had the same problem before. Thanks again.
