Removing fuel injectors
Jim Ch
Can't see it!! I have a 1964 Ford 4000 diesel backhoe/loader,4 cyl. The injectors in the block (4) don't seem to have any bolt head design that I can put a socket or wrench on to remove them. They appear to be round with no visable way of removing them. Any ideas as to what they are and how to change them? JIM
Do you have the Ford 172 engine? The injectors are in the head under the valve cover/rocker arms on that engine. Each injector is held down in the head with two bolts/studs.
Good morning Rich, still gonna ship that IP to you, been so busy, and for the injectors on the 4000 after removing the two bolts I use a small crows foot and pry the out
