Removing mirrors
Stan in Oly, WA
In the living room of a house I own there are three mirrors secured to the wall with mastic. There is no way to find out what type of mastic was used. Each mirror is about 30" wide and 84" high. They are side by side. What would be the least dangerous way to remove them from the wall? The mirrors don't have to survive the removal, but I'd like to.
Stan
I removed some very large plate glass mirrors from the local football club Stan . That's Aussie rules , not the US version .
These were eight feet by three and stuck to the wall with silicon .
I made a long ' cheese wire ' cutter from some fine stainless steel cable and short lengths of 1/2'' rod . It took two of us , one on each end to 'saw' the mirror off the wall .
No real danger , no damage to glass or silvering and none to the wall.
If the mastic is still pliable, the suggestion regarding the wire is very similar to the method used for automobile glazing repair, there is a tool with a knife that cuts the glazing gasket and I believe there are tools that use wire.
Stan, if you will be handling plate glass, do yourself a favor and get some kind of hand pump glass suction cups, you need a pair at minimum, for this job I would use 3 because its tall and narrow. Apply them to the plate glass, then work on breaking the adhesive bond, you will need a second person to hold the plate glass mirror and secure it. Use care not to flex the glass, this is a narrow piece, so carefully work your way down with the wire.
I don't know if wedging is a good idea, but it sounds like one to help provide some space to work. Remember, glass can react and break, and its unpredictable when stressed. You do NOT want to unexpectedly break this glass while working on it. I'm not sure what thickness plate you have here, but given the extremely sharp nature and un-predicability of this material, I will suggest from years of architectural glazing installation, repair and mock up testing in labs, there is always a method and a special tool to safely handle glass, its that simple.
CR Laurence is probably a high end supplier for both Auto and Architectural glazing needs, tools, supplies etc. I just post it for an example of the glass suction cups, maybe you can find these cups less costly, speak with your local glazing shop for some tips, safely remove the glass mirrors and re-sell to offset the costs of said tools to remove.
One thing I learned from supervising glazing crews, when removing existing intact or damaged glazing, experienced hands are best employed for many reasons. I would often get a repair call from a project manager on a building construction project regarding broken glass, our work usually, damaged by their laborers or other trades. Every job was unique, just like glass, and I used my most experienced people to get the job done safely, it really stood out, their experience and knowledge, on how to handle each job. I often reflect on larger and less applicable commercial work I've done to relate to small work, this is un-tempered plate glass mirror, when it breaks its dangerous, both airborne particles, and large pieces, use lots of care when handling this.
If you are going to keep the glass for future reference, make a wooden crate of sheet goods and 2x4's, pack carefully, and do not let it get wet, or allow water between to get in between the plates, you could separate them, but that puts point loading on the glass, there may be adhesive soft blocking or packing materials for this, or just stack them tight together, put a piece of foam insulation board over the last one, then close the crate. Loose plate always gets broken, and is always dangerous when it does.
CR Laurence
We're in the process of remodeling our master bathroom. There was a 3'X3' mirror glued to one wall that needed to be removed. It had been there since the house was built 16 years ago and is a nice mirror with etching around the edges, etc.
The mastic was still pliable and the guys that removed it simply poked around the edges with putty knives and worked it loose a bit at a time till it finally let go completely, with no damage to the mirror. The key here seems to be patience, don't just try to yank it off in a few seconds.
Thanks, everyone. All the suggestions are good and all the advice is to the point. Based on the warnings Billy NY included, and on my wife's 100% opposition to me trying this, I think I'm going to leave the removal to glass company professionals. I was going to do it as a favor to the buyer, but she said she's totally fine with paying to have it done, and there are other, safer things I can do that will mean just as much to her.
Stan
Probably the best decision, let the pros do it!
I've gotten a couple down without breaking them. I criss-crossed them with duct tape, put on welding gloves, goggles, and long sleeve jacket. Just started wedging it out with scrapers and putty knives, gently prying across the wide dimension. It was a scary process! The paper on the drywall finally let go, so there was some repair afterward.
Tried the wire saw method, didn't work, just gummed up with adhesive.
If your superstitious and worried about the 7 year bad luck thing. I'll come over and break them up for you as what's another 7 years of bad luck I've already had 52 ! LOL.
A glazier told me he only uses clear silicone to attach mirrors because any other type tends to deteriorate the mirror surface [ which is on the back of the glass.]
(quoted from post at 12:38:00 08/26/15) A glazier told me he only uses clear silicone to attach mirrors because any other type tends to deteriorate the mirror surface [ which is on the back of the glass.]
...................... and I was told by a glazier to never use any silicone as the acids in it will eat at the silvering on the mirror. There is a reason that they make mirror mastic.
I am a glazer and have removed many mirrors first thing we do is duct tape the whole mirror gloves and safety glasses are a must start at the top with wood shims and a prybar work your way down the problem is if the used a mirror mastic it will be a little easier to move but I have run into where the use a pl 400 construction adhesive with the mirror taped just start breaking chunks of mirror and throw in a garbage can take your time
