removing rivits
Shane Hansen
hey guys I was just wondering how to you guys remove old rivets from a disk blades I got the blade side rivets ground off and blade removed and bearing out of the hub now I gotta get the rivets out of the hub deal. anyone got any ideas on how to remove them. pleasd let me. know thanks
I'll try and upload a picture
After they're ground off set a 7/16" or 1/2" socket butt down on the anvil or something similarly heavy and solid and position the hub over the socket so the rivet head is inside the socket. Then get out your punch and hammer and drive it out. Might take a helper to hold the hub WITH A PLIERS so his fingers don't get stung. They won't come out easy.
Check to make sure the socket is big enough to let the rivet head fall down into it. Ask me how I know why! LOL Jim
Like the others said grind them off flush and punch them out. Use a punch as near the size of the rivet as you can. They are not too bad to drill out either. Rivets are soft.
well ill have to try that Idk maybe I should grind off the other end opposite of the disk blade ? because Ive been grinding off the disk blade rivet then tried to push it through but I guess I could give it a try again. What im doing is this disk blades are perfect size for my 494A fertilizer openers but the 7200 planter fertilizer coulters the bearings were bigger and the 494A hub is smaller so im going to switch out bearings and put them back on. and see if that works.
