removing sheet metal
yea i removed the tach and batt and that gives you alot of access. i looked at the manuals wire diagram and see the only circuit that is fused is the headlights, everything else is direct 12v feed.
The easiest way is you have to take out three bolts on each side of fenders then removing lower dash panel that will give easy access to all the wiring.lets hope when he painted your tractor he used paint hardener to avoid any unwanted scratches. Forgot to mention there is a 1" clip holding the upper & lower panels together you can pull it out no tools required and keep the hood closed or latched just to keep the fenders from moving to much.
