When I overhauled my '49 8N I didn't have any difficulty removing the intake valves using the notched screwdriver method. I also modified a curved prybar/scraper I had by
notching out the center to fit around the valve stem. The exhaust valves were more stubborn as one was so stuck I cut the spring into three pieces to get it out. I just did a
valve refresh on my '51 and the exhaust valve came out super easy and they also had seals on them which I did not put back. The intake valves were the opposite, I had to pry the
spring down and snatch the clips out. Upon close inspection I could see that the block casting in the valve port areas especially on the intake ports is made different and takes
a different approach to getting the clips out. When I put them back in I was able to pry the guide down just enough to get a screwdriver into the clip groove and get the clip
started and then tap it in with a hammer. Has anyone else run into this on late block vs. early block engines. I updated the exhaust valves to rotators and all adjustable
lifters. Every valve guide had a seal on it, I only replaced the intake seals. The block has red paint on the surface where the manifold goes and I'm wondering if this engine
has ever been disassembled.
