Repainting over old paint
I would be leary of doing so at least in my case I am removing all old paint back to vergin metal since the last time it was painted was in 1988 or there abouts and the paint was not auto just home hdwe metal paint, the original IHC dark red was still in places underneath so I just wanted a quick even paint colour at the time and it was what I afforded ( 1 GAl for $25.00) ouch! So now I am totally restoring. Try a small area and then deside.
W. E.J.
I prefer removing it. Chances are there is rust underneath. At a minimum it needs to be scuffed or sanded or the new paint won't have anything to stick to. Best to use epoxy primer over the old paint. There really is no easy way if you want a good job.
I would suggest taking a look under the existing paint first. I have a 1957 that needed a paint job, even though the paint that was on it was basically intact. once I got through that top layer it was amazing how much rust was underneath due to inadequate prep for prior job
I would make a suggestion. First go out and price an average quality paint. Then, with that in mind, come home and wash your tractor. Good soap and water bath to remove most of the dirt and then a spray down with lacquer thinner to get rid of grease and oils. If the existing paint starts to peel, ask yourself if you really want to spray your new paint ($$$) over the top of it. At that point a good going over with a Scotchbrite pad to get rid of some of the rust and loose paint is about as good as you will get without disassembly. I would still follow the advice to use epoxy primer. Also keep in mind that every defect in the existing paint will show thru. I painted my fenders and dash twice. Once over the existing paint and then again after I sandblasted it all down. Looks MUCH better now.
C'est la vie!
I did on my garden tractor since the tractor had always been sheltered. I power washed the tractor after removing the hood, fenders, wheels and seat. I hand sanded all the parts then wash them with warm soapy water and then rinsed
them. I used an epoxy primer on most of the parts followed with a surfacer. I then used acrylic enamel for the finish coats. Hal
PS: I removed the sleeve hitch and the S/G too.
I use Primeez sold by Napa stores and I use it over epoxy primer on sheet metal where you want a smooth surface since it is sandable. I use it on the frame & rims since I think the finish coats will adhere to the surfacer better than the epoxy primer. You thin it with lacquer thinner and it dries quickly. Hal
A surfacer is a primer paint designed to fill minor imperfections and is sandable so that you have a good smooth surface. They come in low build to high build which has to do with their filling ability.
As for the top coat sticking better to it than on epoxy, If using epoxy there is generally a window in which the top coat must be applied, 72 hours. If it is not applied within that window the expoxy must be scuffed and re-applied. The reason for this is that the epoxy forms a chemical bond rather that a mechanical bond such as painting over sanded surfaces. The adhesion is just as good over epoxy as sanded surfaces.
