Replace 801 front crank seal
WGregB
Looks like I need to replace the front crank/timing cover seal on my gas 1959, 871, no loader.
Is it feasible to try this without removing the engine or front of the tractor (hood & radiator)?
I'm far more familiar with the 3 cylinder Fords but I think? your 4 cylinder will be the same. To replace the front engine seal the timing cover must be removed. To remove the timing cover the the front engine mount (bolster) has to come off. And that means the hood/tin has to come off.
You may be able to leave the radiator on the bolster but you will have to drain it and disconnect the hoses.
I would be caught taking the radius arm and tie rod loose on one side and swing the axle bolster with rad out of my way.
