(quoted from post at 18:47:46 12/24/10) There is a loader on it and a front mounted hydraulic pump. There is no room between the pulley and the front axle pivot
(quoted from post at 23:15:17 12/24/10) The edit function is not working here so I had to put this in another post.
You won't need to unhook any hydraulic lines. Just undo the pump from the base and pull it forward a bit, maybe wire it out of the way. Then undo the coupler so you can get out that bolt that screws into the drive shaft. Remember the left thread.
(quoted from post at 09:50:12 12/25/10) Would you happen to know if the Wagner loader pump is a spline or the left handed threads?
