Keith Molden
My drum mower started throwing the knives on the outside drum so yesterday we pulled the bottom dish and replaced the knife holders. They were worn so bad on the inside that the knife would slip out and go flying never to be found. I found the old ones were also bent. They weren't hard to replace after we removed the top cover and curtain (it came off as one unit held on by 4 bolts. Then turned the mower on it's side, removed the 3 hex head bolts and removed the bottom dish. Those blades do get to be expensive when you loose them without hitting anything. I think it will mow a little bit better now when the 2nd cutting comes on. Only took me and the wife about 3 hours from start to finish and not working fast at all. I've had this mower for at least 8 years now and this is the first thing I've ever had to do on it, so other than either flipping or replacing blades, that's pretty good. It's a Minos mower. Keith
