(quoted from post at 10:33:50 01/13/23) This site sells the switch for less than $10.00
Never would have thought the key would come out in the run position, didn't say anything in the online listing. My local store does show 1 in stock so I'll stop by and check it out. They didn't have the KS6041 in stock when I checked.(quoted from post at 07:41:20 01/14/23)
Read this.
https://forums.yesterdaystractors.com/viewtopic.php?p=7709500&highlight=ks6040#7709500
Run from those so called cheap switches they are just plan JUNK!
I may have ran across another NAPA switch that works I am not in the shop to research it.
(quoted from post at 00:10:32 01/15/23) OK, I've got an ignition switch that's a good switch. My local independent store carries Standard Motor Products brand. Owner went to the shelf and pulled off exactly what I wanted. It's a 2 terminal 2 position ignition switch. Key does not come out in the on position, only in the off position and comes with the backup nut and the outer bezel. Looks like the Echlin in the pictures, probably the same part. Part # is US64 and was $20.
Thanks Hobo for the pics and links
This post was edited by Eman85 on 01/14/2023 at 10:18 am.
