Replacement rims for MM BG
T.R.K.
10 x 24 rim. I have a hole in it bigger than my hand around the valve stem. I am thinking it is the same rim as used on the Farmall A and
perhaps other tractors. 4 lugs for the wheel center to bolt to.
I am looking online for a replacement rim.
Do any of you guys know for sure if a Farmall rim will fit?
Will any of the replacement rims work with the square head bolts that are on there now?
Thanks!
T.R.K.
About 10 years ago, I needed rims for the same reason. I went to the local tractor tire store. Told them what I needed. They ordered the rims. I cut the hubs out and welded the hubs back in the new rims. Put a coat of paint on. They look better than new.
If the rest of the rim is solid and not a show tractor. why not repair the hole and drill a new valve stem hole. I did what Tony suggested with the wavy flange rim on my JD M. I bought blank rims and removed the wavy center and re-welded. Don't know where you are located, but I think I still have a blank 24 rim as I only used 1 on the M. I'm in SE MI.
