Replacing coulter disc on plow
Bought this old plow a year or two ago. With help from more experienced people here I think I have it figured out on using it. Only issue I have now is a broke coulter disc with a bad axle. I can't seem to find a replacement a dealer was able to find everything but the brass bushing. I tried Shoups but the disc I see they have look like they use a bearing and had design more like a trailer spindle. So I guess my question is does anyone have an idea where I could get a coulter disc and axle that I could use? I need to replace to tube that mounts to the connecting rod that bolts onto the plow so width of the axle I don't think would be an issue as I can change it when I weld it back together. I added a photo of the disc if that helps explain what I'm attempting to fix.
Wish I could have enough of pick to tell what you have. Not clear and does not show enough of plow to tell what kind of plow you are talking about. Better pictures might get you better answers. Cannot see a coulter disk.
Agri Supply has a hub with bearings and a 3/4 axel bolt. I bought 3 to fix the coulters on my plow along with 3 new blades. Took a little work to make everything fit but was the least expensive solution I could find.
I bought a piece of 3/4 OD 1/2 ID tubing from online metals and bushed the hubs down to 1/2 so I could use 1/2 inch bolts for the axels. My forks would only accept a 14" blade and the blades I bought didn't quite line up with the hub holes. A few minutes with a die grinder on the blade holes solved that problem. Don't remember the exact cost but know my total outlay for 3 new hubs, 3 new blades and hardware was under a hundred.
I'll definitely have to call them on that. Might be my best bet. Little grinding and welding never hurt anyone anyways. Plus I need to do some of that anyway. Thanks for the link it'll help a lot.
(quoted from post at 07:19:08 03/23/17) Wish I could have enough of pick to tell what you have. Not clear and does not show enough of plow to tell what kind of plow you are talking about. Better pictures might get you better answers. Cannot see a coulter disk.
Seems every opinion I've gotten on projects like this has help. Hope these pics show better what I have going.
