soybeanjoe
I rebuilt the range shifting deck on my 806 last fall. Early this spring we started having trouble getting it to go into reverse & finally got to the point it wouldn"t go in. Only use this tractor on an auger in the fall & a side mount ditch mower in the summer so I parked it in the shed until a couple days ago.
I took the "indiana" cover off the side & found a small piece of metal laying on the cover"s ledge. I proceeded to drain the rest of the oil. With the oil drained I ran a magnet around the bottom of the housing & came out with 3 small pieces of metal. One was a small roll pin, another was part of the rever shifter fork where it pivots, and the other was the pivot pin which the original piece had broken off of.
So, I need to replace the shifting fork. How much of a job is it? Can I remove the range shifting deck, pull the shaft up & remove the fork thru the "indiana" opening?
TIA,
boog
TIA,
boog
