Resistor or not?
Baney
I am currently in the process of upgrading my 42 9n to 12 volts. I have replaced all the wiring to the appropriate scheme as directed in one of the diagrams I pulled earlier from this cite. I also replaced the old coil with a new 12 volt coil. The question is do I need a resistor between the ignition and the coil if it is a 12 volt coil. Right now, when I turn the ignition switch on the resistor smokes. Is this indicative of a failed ground issue.
1.) Commonly, the OEM resistor is needed and left in place with the so-called "12-Volt" square-can coils now on the market.
2.) 'Most ALL new ballast resistors SMOKE from an oil film or whatever left on them from the manufacturing process.
3.) A "failed ground issue" sure isn't going to make the resistor heat up any more than normal!
4.) DON'T just sit there with the ignition switch "ON", engine not running. If the engine has stopped at a point where the points are closed, there will be 4 Amps (give or take) flowing in the primary ignition circuit, heating up the resistor, coil, and breaker points for NO good reason.
Of course, if there is a short in the distributor or elsewhere in the primary ignition system the resistor will carry current and heat up even if the breaker points are OPEN.
It used to be before the "Land of Almost Right" started making coils and importers w/o quality control started selling them that you could count on a 12v frontmount coil as having 3 ohms of internal resistance & the 6v coils as having 1.5 ohms or less. Thus, thanks to Ohm's Law, you could calculate what additional resistance you needed in the circuit to limit coil current to 3.5 amps. So, you will need to measure the internal resistance of that alleged 12v coil & see what it is. A digital multi-meter has two probes & a switch. Set the switch on resistance. Put one probe on the top of the coil & the other on the pigtail at the bottom, just like in the picture above. It will give you a reading in ohms. Lets just say it reads 3.0 ohms. Your OEM ballast resistor (which you must use, like Bob sez) is about 1 ohm hot. A coil a 3.0 ohms, plus the ballast resistor at 1 ohm (hot) gives you 4.0 ohms resistance in the circuit. Your 12 volt alternator puts out 14.5 volts. You need to determine current (amps). 14.5 v divided by 4.0 ohms gets you 3.6 amps; close, and probably safe. But, and this is the problem......what if the coil is only 2 ohms? Do the math. 14.5 volts divided by 3.0 ohms gets you 4.8 amps! Not good! And, if the coil is less than 2 ohms (and some are) it will fry quickly. So, to get it to 3.5 amps, you need another resistor in the circuit. Either that, or keep spare $30 coil around.
50 Tips
failed ground? In my book that would be an 'open'.. with an open.. there is no current flow.. with no current flow there is no heat.. with no heat, there would be no smoke.
Bob and bruce gave you good info.
soundguy
