restoring #5 sickle mower
Johnny50
the crank wheel ( the pitman arm hooks to it) on this mower seems to be just pressed on with a keyway. Do i have to use a puller or should this just come off with a a few hard taps with a hammer?
thanks for any advice
I have removed some of those and they can be pretty easy or extremely stubborn. One I had to remove the shaft and flywheel together (yes, it can be done) and press the shaft out with a hydraulic press. Be forewarned, that flywheel is not as heavy and solid as it looks from the outside and they will break. Let me know if you need any parts.
