Resurrected the old swing mower
formerly ny bill
The weeds took over a field that was plowed but not disked. I dragged the old NH 114 out of its shady resting place of the last 15-20 years and got the
field mowed, after replacing 2 hydraulic hoses and getting a new belt for the reel. Still need to replace some knife sections that got the tips broken
off, and a bearing on the auger gave up, but it was better than beating up the discbine.
Well it is the machine behind the tractor in the picture! ; > ) It is basically a self propelled swather header with a hitch and frame with tires to pull it behind a tractor. Where the hitch beam connects to the machine there is a pivot that has a hydraulic cylinder that will swing the header either left or right. This way you can drive beside a crop on either side and swath it without driving in the standing crop. and at the end of the field you can turn around, swing the head to the opposite side and cut crop along where you had just laid crop down. A hydraulic pump that mounted on the PTO drove the machine. I may be wrong but I think Hesston was the first builder of the Hydra-swing style of swather.
Correct description. It swings from the center, vs side pull like the smaller mowers. Once a field is opened up (55-60' will give you room to turn and swing the mower to the other side without stopping), you just mow. No dead time crossing the headlands, much more efficient.
The machine came into a consignment auction from a dealer, when I bought it. Always a red flag, but it looked decent. And it cut (14') half again more than the NH 488 (9') I was using. After using it a little, with constant conditioner plugging issues, and much head scratching, I realized that the conditioner rolls were turning at different speeds, changing timing on the rolls. The idler on one chain was gone, so the PO just shortened the drive chain. DUH! After I built a new bracket for the idler and got the right number of links back in it, it worked great. Two reasons I parked it- it can only windrow hay vs lay it out flat to dry, and fine grass hay tends to make the sicklebar plug. The discbine solved both those problems. On coarser material, the 114 works decently.
It is something that I have never heard as well. Must be a regional thing to call it a swing mower. It is called a haybine in most countries.
I call it a swing mower to differentiate it from a 469-479-488-489 etc side pull haybine. In Nebraska, it would be a swather, I suppose.
