Revisit JD DESTROKE VALVE
lenray
SO I bought the valve that Worthington sells and all of the sellers on ebay sell.As you guys said---it must fit a newer JD PUMP----Not the original JD Hyd. pump. I can do the steering wheel trick with varied results. WHERE CAN I GET A DESTROKE VALVE for a 1961 JD 4010 WITH THE ORIGINAL PUMP?????
THANKS FOR THE PREVIOUS HELP.......
As told you before, the smaller destroker (Key #6) that will LIKELY fit (AR33249) is no longer available from DEERE except as individual parts.
34H54 Spring pin $1.49
A4365R O-ring $1.09
R26448 O-ring $1.69
R27171 Screw $16.00
R27475 Fitting $18.61
For a total of $38.88.
If you decide to order, double check that I didn't transpose or otherwise mess up a part number!
