riding mower
Been working on a neighbors craftsman riding mower.The crankcase was full of gas,Stuck neddle,.now I can,t get it to move,tried all levers, but won untrack.has a metal rod sticking out below steering wheel,with no knob,and don,t know it,s purpose.its an Intec17 ohv automatic 42 inch cut .Will check more en the morning.Anyone worked on one of these,and what do I look for
the metal rod below the steering wheel is the parking brake i have the same mower, it should be in the down position to release, if the unit has sat all winter with it applied it may be frozen to the brake disc, youll have to raise the mower up and see will it try to move or just nothing at all? i know you have already checked to see that the drive belt is properly installed
Hello ken in texas,
They are known bad needle and seats on that size engine. You need to replace both. The seat is pressed in, get a screw to fit in the hole and pull it out. Make sure the float is O. K. and not sticking. You need to push the clutch in to take the parking brake off. It also has to be in neutral for the mower to be moved.
Guido.
Can you move the mower while the transmission?
If one of the rear tires was removed from the axle to fix a flat tire maybe the square key was not replaced when the wheel was replaced. The axle will turn but the wheel will not.
