mikegold77
trying to figure out what is the best rim size for case 430 14.9 tire? 12inch 13inch? what is the widest you can go? thanks
14.9 width tire goes on a 13" wide rim. Should say so right on the tire itself, but maybe not.
12" you're pinching it giving the tread a more crowned appearance. 14" will be easier to mount but the tread will be more spread out and flat.
I have a 1964 MF 65 and a 1966 MF 165 that both came with 14.9 x 28 tires on 12 inch rims. I also have a 1969 165 that came the same size tires on 13 inch rims. Either will work just fine. Bear in mind 14.9 tires replaced 13.00.
