Rim/tire mounting combination
Epjisme
I recently bought an IH 606 with loaded power adjust rims. Needless to say the calcium ruined the rims. I found a set of discs and rims to replace them with but not sure of the best way to mount them,dished in or out and then what position to mount the 6 loop wheels to the disc. I know there are a lot of different options just wondering what your thoughts are on it. Thanks.
You really have to decide that for yourself and your circumstances. Do you have width restrictions where you store or run it, so you might want it narrow? Are you doing any crop work where the spacing needs to match rows? Is it a wide front, where you want the rears to track the fronts? Are you going to run on side hills? How wide are the spin outs set? Is that width good for you? By turning the discs dish in or out, turning the rims, and using both sides of the loops you have may choices.
I'd set them mid-way if there were no other governing factors and with a wide front, center its width to the rears. JMO, Others may have different thoughts.
