300winchester
Can anyone offer advise on proper seating of rings for a JD400 industrial. We are putting in new sleeves and pistons and want to make sure rings get seated.
Thanks in Advance
MGM
Thanks in Advance
MGM
(quoted from post at 20:23:30 07/09/18) Every engine that I have rebuilt using chrome rings has used a little oil from the start. Not much, but still. The ones that I used the cheap cast iron rings,never used any oil from the start.
I tried everything to get chrome rings to seat,but
no luck.
(quoted from post at 19:15:18 07/09/18) Cast iron rings will seat in very quickly, but they have a much shorter life than chrome rings. Chrome rings will take a while to seat unless you have a good crosshatch pattern in the bore. BUT, chrome rings will outlast the cast iron ones by a long ways. Just a matter of how often you want to do a ring job.
(quoted from post at 03:15:18 07/10/18) Cast iron rings will seat in very quickly, but they have a much shorter life than chrome rings. Chrome rings will take a while to seat unless you have a good crosshatch pattern in the bore. BUT, chrome rings will outlast the cast iron ones by a long ways. Just a matter of how often you want to do a ring job.
