Rings needed
730-LP
Need 4 compression rings and 2 oil rings.Bore is 6 1/4 and the compression rings are 1/8" thick and the oil rings are 1/4" thick.Has anyone got a source for these?Any info would be appreciate.Thanks
(quoted from post at 01:09:49 02/26/10) Need 4 compression rings and 2 oil rings.Bore is 6 1/4 and the compression rings are 1/8" thick and the oil rings are 1/4" thick.Has anyone got a source for these?Any info would be appreciate.Thanks
I've used a CAT set, but the top Comp ring was 3/32 I think. I'll see if I still have the box.
Use a ring set from a 720/730 diesel @ .125" over. nnalert P/N A 1489228. Theses are to be Hastings rings.
Give us a call, we are a factory direct Hastings ring dealer and with our discount we can sell you the rings you need cheaper than they will. Alderson Tractor 641-624-2275
